Will we fit on the channel tunnel
Burtonsontour
Joined
Feb 12, 2025
Messages
9
Points
13
Member No
10,255
RV Type
Looking to buy
RV Experience
Total newbie
Has anyone taken their RV on the channel tunnel. We have a Thor Ace 27.2 and according to dimensions we are just OK but hubby getting nervous as the trip gets closer.
Would be great to hear from someone who has done this and not got stuck.
No LPG conversion for engine which I know is a barrier for some.
Also planning ferry back from Spain. Does anyone have a discount code they are willing to share.
Georgina
Projectblue
Joined
Nov 25, 2025
Messages
11
Points
3
Member No
10,386
RV Type
A Class
RV Experience
Total Newbie looking to get into
Can't g'tee about your Thor Ace but I had one of these and my friends took theirs on the Chunnel.
Dimensions are 12.5ft high and 32ft long so you will be fine.
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
MERLIN
Joined
Nov 14, 2017
Messages
224
Points
93
Location
hASTINGS east sussex
Member No
7,869
RV Type
A Class
Model
Winnebago Adventurer 33V
RV Experience
12 years
Georgina
Hi Georgina, yes you will fit no problem. Just remember to take a wider turn and then bring it in line with the carriage. About an inch either side for you mirrors but you'll be going slow anyhow. Beauty is you get to stay in your Rv for the 30 minutes.
Enjoy !
Life Member
Joined
Sep 4, 2011
Messages
11,036
Points
113
Location
lincoln
Member No
2,126
RV Type
5th wheel
Model
Eurocruiser 855 pull by a 3lite toyota pick up
RV Experience
jan 2011 new
Shouldn't be a problem we been across a few times with our 5er 12ft 6ins high and about 14 ft long, as said make shure you get straight take your time can be seem a bit tight, but enough room.
Projectblue
Joined
Nov 25, 2025
Messages
11
Points
3
Member No
10,386
RV Type
A Class
RV Experience
Whilst we are talking Chunnel and to save another thread - are there restrictions on lpg? Is a fixed tank like those found on rv’s ok? Any issues?
Arthur
Joined
Apr 28, 2010
Messages
1,380
Points
113
Location
Marlborough Wiltshire
Member No
1,193
RV Type
A Class
Model
Tiffin Phaeton
RV Experience
When we took our previous bus through the tunnel, I was concerned about the width measured from its left-hand wheel to the right-hand side view mirror, which was fixed - it only moved when hit by a lorry! because as you pass through to folding doors, its a bit narrower.
Essentially, you have a walkway on the left, which is where we focused on making sure the left-hand wheel was touching it. Below is the post I did for someone else when they asked the same question:
When we went through the tunnel in our previous RV, it was set as below, this gave us a couple of inches on the mirrors either side, through each of the carriage doors.
This was reliant on keeping the drivers side wheel just touching the raised pavement on the left of the carriage.
Life Member
Joined
Sep 4, 2011
Messages
11,036
Points
113
Location
lincoln
Member No
2,126
RV Type
5th wheel
Model
RV Experience
jan 2011 new
We have 2 gas bottles no problem as long as they are turned off , and habitation tanks , but if you run on gas,no, OK petrol only ,
Joined
Oct 25, 2014
Messages
819
Points
93
Member No
3,778
RV Type
a class
Model
thor ace 29.3
RV Experience
1 week
The tunnel is so easy timewise.
You will fit!
I allways think the carriges are tight on the wingmirrors but thats it its a long train i like to just lean out me window be close to my side and it meàns you easily clear the other.
YOu be fine
Jev88
Joined
Jun 3, 2021
Messages
1,001
Points
113
Location
Eye, Peterborough
Member No
9,292
RV Type
A Class
Model
Fourwinds Windsport
RV Experience
Coach built Motorhome 3 years
There are limits on LPG and LPG powered vehicles are not allowed.
The Channel Tunnel (Eurotunnel LeShuttle) has strict rules for LPG: you cannot take vehicles powered by LPG or with large fixed LPG tanks, but you can transport smaller, portable LPG cylinders for domestic use (cooking/heating) up to 47kg (approx. 93L) for one container or 50kg (approx. 99L) total for multiple containers, provided they are less than 80% full and have a visible gauge for staff to check, otherwise, your vehicle may be refused.
Joined
Oct 22, 2014
Messages
3,405
Points
113
Location
Peterborough
Member No
3,776
RV Type
5th wheel
Model
Primetime Crusader 325 RES
RV Experience
Many years
Direct from Leshuttle website, I've only travelled with 11kg cylinders & they asked if they were turned off, they didn't actually check, with a fixed tank I'm not sure if they would want proof of the size, or would be OK with you saying "it's 45l litres" & showing the valve closed.
Projectblue
Joined
Nov 25, 2025
Messages
11
Points
3
Member No
10,386
RV Type
A Class
RV Experience
Thanks, that sounds definitive and makes sense. Much appreciated.
Joined
May 29, 2018
Messages
3,741
Points
113
Location
Maidstone
Member No
7,989
RV Type
B-Class
Model
Lexington
RV Experience
35 years with RVs
We have always used Le Shuttle ever since they changed the rules and allowed motorhomes and caravans to be carried. They always used to get you to pull in to a checking area where they asked questions about the size and quantity of LPG your tanks are and physically checked the valve was turned off but, the last half a dozen times I've travelled with them, they just asked me if the tanks were turned off with no actual checks made.
I've not travelled in Europe since 2019 so can't comment on current procedures but it seems to me they were getting slack on procedures?
You will definitely get on to the trains if you take things easy and ensure you're lined up. I've travelled with and without trailers in 9 and 10 metre RVs with no problems and I've watched big, tag axle busses board skilfully
