Just as jayandjen have said I have used several types of silicon and they fail to adhere. Would be grateful for the name of a polyurethane based alternative
OK.
So my winnebago call out sheet used this as the seat on sides / trims / gutters. Which are gelcoat and alluminium.
Pro Flex® RV Flexible Sealant is specifically designed for the recreational vehicle industry. It can be exposed to adverse weather conditions right after application. Pro Flex® RV Sealant has excellent expansion and contraction properties to withstand the joint movement and temperature changes...
www.geocelusa.com
This I could not find in the UK or get posted over.
The closest equivalent I could buy in the UK with similar properties and materials to use with to redo bits where I was unhappy with the factory caulking was this.
A totally unique “hybrid” sealant for use in areas requiring a tough elastic rubber joint or as an adhesive with superior bonding strength.
bond-it.co.uk
It has performed really well and looks great and stayed flexible as required for just under a year no probs.
My window I fitted I used sikaflex. The factory ones are fitted using black mastic ( type used on rolls)
But I am happy using the proflex as a clear sealant.
But as with all things try in a inconspicuous place to test first and satisfy yourself
Hope this is useful information for you bengie.
