Slide out going manual
Bugsbunny
Just a quick question.. Our slide out is not working, nothing happens when pushing button... Mechanic said it might be user error and he had it working and paid for his advice but alas thing not working and we're away.. Grrr.
Considering taking the cap off the hydraulic pump and ratching it out manually so weekend not a wash out... Do i need to pull panel and disconnect switchfirst.. Is it advisable to do it manually at all?
RRV
There should be a manual system of bringing it in. Look under the slide out under the locker - you should see a nut that you can put a socket on and wind it in manually.
Silly question but is the ket turned off ? - you might have a key that turns the power off to the slide out. if you have try turning it
Good luck :)
