we have in excess of a ton load capacity, so Weight isn’t a factor in the decision.Another consideration will be weight, a 120 litre tank will weigh around 120kg when it's full. How much spare capacity does the trailer have?
Google car-gas lpg conversions stoke on Trent name is john they fit tanks etcWe have now collected our new Eurocruiser, we are away for 15 nights, we are on our 3rd day away and have used half a safefill cylinder of gas, about 6l.
So we are considering having a lpg tank fitted, looking at 120l tank, has anyone else fitted an lpg tank to their fiver?
we do a lot of da camping, they don’t allow cylinders over 13kgs so can’t use them.Have you got an extend-a-stay? Then you can use an external gas cylinder, most suppliers will exchange cylinders for different sizes, so if you're somewhere for a long time you could get a 47kg which is just over 90 litres. I simply changed one of the hoses from the regulator to a 2m hose so that I can use the larger cylinders in the winter.
Some sites are a bit funny about free standing cylinders though, gas is also cheaper buying 47kg, I'm paying under £50 or was a couple of months ago, I'll find out if it's changed soon.....
I asked advice, people have discussed what they do, and what they use, it’s been informative, but in some cases the suggestions don’t comply with C&CC rules, so unfortunately we can not go that route,Sounds like your telling us what your doing not asking advice
we currently use safefill cylinders, 22l costs about £10.60 the diesel heaters use .64l an hour the gas heater uses about 1l per hour (according to manufacturers and users) so at this point I don’t see much difference in cost between diesel and gas running costs, having said that, it depends how far the room stat is cranked up, we have our heating set at 18 degrees c at the moment.Just for reference I run a 30ft 3 slide fiver at the present time. We used to do trips of no less than 90 days at a time. We use a mixture of stellplatz, aires and campsites sometimes with, sometimes without hookup. I have 2 gas lockers built in, each holding a 13 kg bottle. Before fitting the diesel heater when not on hookup and during coldish weather I used a bottle every 7 days. Since fitting the diesel heater a bottle lasts between 18 and 22 days. Admittedly, this was in late summer in Germany, but I would expect similar in winter as the fridge freezer would not require as much gas. My 400 watt solar array and 400 amp battery bank handles everything indefinitely, but after over 20 years of RVing I know for a fact that if I relied on LPG for my heating requirements I would be wearing thermals after a few days of cold weather with no sun.
what is an extendastay kit ?We have extend a stay good kit to have but may fit diesel as its tank is easy to run to the garage for refill. And heater is knackered and obsolete
