Hitching and in hitching
Faz77
We have sidewinder on our Rockwood 8280. You have to get the angle absolutely spot on so that kingpin and wedge engage in hitch properly. Only time I’ve had real problem was when the wedge was wrong height and locked in the jaw took a number of attempts rolling forward and back before position was right and handle could be disengaged. If you are having to persuade with a hammer then wedge is probably the problem. If you haven’t already bought the hitch on eBay I’d try fixing the sidewinder and removing the wedge. Rig will then rotate over the truck rather than at the van end. Might also make reversing on easier as kingpin arm will always be straight rather than at whatever slight angle your last reversing manoeuvre left it at.
8
8629
Guest
im considering a pinbox extension and locking the pin box, but wondering about the extra leverage and how it affects the chassis of the camper.
It sounds like you have the earlier sidewinder with the single large nut underneath, I have just activated my sidewinder as it was supplied locked ( inactive) and it may improve things if you slacken off the wedge bolts then re hitch. With the pin box engaged with the hitch with a hide hammer tap the wedge towards the pin as far as it will go then re tighten the bolts.
