Dometic fridge not working
Before she went to storage before Christmas all was working fine pulled it out of storage today to go away next week nothing working tried it on gas no luck plugged in the EHU no luck
Not working on gas or electric
Getting 110v 12v and gas to it ok
Just wondering if RV is so cold the fridge thinks it at correct temp so not cutting in
Going to get heating on and warm it up and get it de-winterised
I’m wondering if it’s the thermistor playing up as it’s one of those snip the tip ones could I short it out will that fool the fridge to come on?
Garth,
Go to the outside of your rv to the fridge vent open it, you'll see 3 or 4 spade connectors remove them carefully spray them with wd40 remake the connection and then remove them again do this 4 or 5 times and it should work again.
Will let you know in a bit if that’s worked
but can’t believe that the RV was so cold it was colder than the fridge
A fridge runs at around 6°C, the ambient temperature hasn't been much above that recently. ....although I must admit that I've never known our fridge not to ignite!
