Dash Heating Temp.
This is for petrol pullers only.
How warm is the air from dash when travelling and what on the gauge is your engine temp showing.
On Dot4, temp gauge is as photo. We do get warmth through vents but expect it to be a lot hotter. As we are not normally in the cold months of UK winter, not really noticed it. Till Now.
David&Rhona
Temp does look low on the gauge. It indicates it could need a new thermostat and possibly flush the heater core. If you don't use the heater core periodically to circulate, it gets clogged with sediment.
Thanks. Brand new thermostat when rebuilt engine, it's always shown that on gauge.
Think heater core is behind panel on footwell, with aircon unit. Will try a flush when back at Shrewsbury later in year.
David&Rhona
I am not sure what you have for a unit, but since you have a new thermostat, it could just have a lower temp thermostat.
Paul Michael
Hi, I have a Damon Daybreak.
If i just turn the dash heating to hot, it is not warm enough and seems luke warm.
If i turn the air-con ON and then turn it to hot, it is roasting!
Have you tried that?
Does it have an isolator valve? I know that some Ford vehicles do, usually vacuum operated, it prevents the hot coolant from circulating through the heater core when using max AC for better cooling in hot places. My diesel engined truck doesn't but it's often added to make the AC more efficient. If your RV has one it could be stuck or restricting the flow.
What could it look like,
Brian,
When you rebuilt your engine, when filling your engine with coolant you might have several air pockets in the engine.
This will stop the hot air coming tho
Did you bleed the the coolant/pipes in your engine ?
If not turn your heating temp to the max with your fans on max to, air con turned off rev your engine to 2000 revs for 10 minutes then open your coolant valves you should have several valves around the cooling system.
Open the first one (valve) at the highest point, then open the others this will remove the air if any.
Hope this helps.
Brian,
Did you bleed the the coolant in your engine ?
Hope this helps.
Thanks, she has always ran cold so engine build make no difference.
This is an image from the Web, but it would give you an idea, it may not have one, it would be on the heater inlet pipe somewhere.
Well can not see this item fitted on Dot4. A guy from IRV2 who used to work/sell Ford Rvs said there is a conversion kit available, or used to be. A second matrix which goes in front of existing heater matrix.
If nothing else it will give me something to look for.
Mines not to bad, usually turn the auxiliary on which is another heater under the floor on the passenger side it blows into the heating ducts.
Standard fitting on the Brave DU no idea if other models of winnies have it, its fitted behind the water heater in the front passenger locker, simply a stand alone heater run of the engine coolant which blows into the underfloor heating ducts, as its at the front most of the heat is felt at the front. Two speed switch on the dash.
think most of it has been covered I would look for air locks, but if it has always been low try a different thermostat that opens a little later, rv's sometimes have thermostats changed if they are constantly used in hot states to allow it to open more frequently.
