No reverse lights E450 SUPER DUTY V10
Discussion in 'General Tech & Mech' started by Andy n Loi, Feb 6, 2010.
  1. Andy n Loi
    Andy n Loi Guest
    No reversing lights
    Ive just bought my first RV. Its a C class Ford E450 super duty v10 petrol with auto trans. It has the Forest River body 3100ss and is 2 years old in March with 3000 miles on the clock. I have checked all relevant fuses and relays which all seem ok. They tech guys in the states reckon its the pcm module which is located inside the box, need to drop pan. i cant believe this is all neccesary just for reverse lights.
    Any suggestions, or anyone give me a figure to come and fix it. ??? Or anyone wanna swap for one thats all working. ( you wouldnt believe how __ssed off i am .
    Its the new shape E450 if thats relevent.
    Ive checked the bulbs !!!!!
    Regards Andy
  2.
    Subscribers don't see this advertisement. You can subscribe for just £10 a year  Click here
  3. andy
    andy Member
    Mar 13, 2009
    169
    Rotherham
    RV Type:
    A Class
    Model:
    Four Winds Infinity 34k
    RV Experience:
    3rd year gone,now on 4th
    Sorry i cant be of any use but it looks like you need to PM Damondunc,the Starspangled spanner man,he's the man of knowledge,and well recommended by all.regards Andy.:thumbup:
  4. Big Cubes
    Big Cubes Guest
    The pcm is inside the box , but its a simple job to rewire the reversing lights on an external switch with a bracket so they still operate when moving the selector.
  5. madbluemad
    madbluemad Guest
    Andy, dont worry about it mate. I get a new one fitted every year for the mot. Two weeks after a new one's fitted it gets bust, it then stays bust till the next mot.
    Jim
    :001_smile:
  6. Andy n Loi
    Andy n Loi Guest
    Thanks for taking the time to reply.
    OK, I thought of putting the reversing lights on a flick switch on the dash and running a fresh feed to the lights , im not following your suggestion , are you saying theres a live from the gearlever to be obtained when reverse is selected.
    Andy
  7. Andy n Loi
    Andy n Loi Guest
    Jim
    Do you have the same vehicle or transnission ??. Is this a designj fault ??
    Andy
  8. signature
    signature Trader - RV Dealer
    Jan 20, 2010
    301
    11
    Wolverhampton
    RV Type:
    a class
    Model:
    Thor
    RV Experience:
    over 20
    Lights
    Andy
    Not sure whats going on there, we supplied most of Forest River sunseekers at westcroft and to my knowledge i have never heard of that, if you want to give us a call you can speak to Jason, he has worked for me for a long time and would have done the original conversion on your sunseeker (if its a westcroft van) so can talk you through a few things to check.
    We have 2x used 3100 and 2x new ones, will have a look at ours.
    We are now the Forest River Importer again in the UK.
    Steve signature.
  9. Olley
    Olley Subscriber
    Jul 20, 2008
    4,688
    784
    Ipswich
    RV Type:
    A
    Model:
    Winnebago Brave 31'
    RV Experience:
    30
    I expect he means that you put a feed down to a limit switch mounted next to the gear linkage, you mount it in such a way so that when you select reverse, its operated. Sounds a sensible suggestion. You will need to ensure any switch is IP54 rated minimum or better.
    RS do a very extensive range here: http://uk.rs-online.com/web/search/...method=retrieveTfg&Ne=4294957561&N=4294957311
  10. Geo
    Geo Subscriber
    Oct 21, 2008
    3,565
    678
    Mansfield,Notts
    RV Type:
    A Class RV 36ft 7"
    Model:
    Damon Challenger
    RV Experience:
    30+
    Then leave it bust
    its not a testable item:cursing:
    Geo
  11. You beat me to it Geo!
    I thought it was not in the MOT test!!
    Regards Pat
  12. MAUBRI
    MAUBRI Subscriber
    Oct 1, 2009
    169
    10
    REDRUTH
    RV Type:
    C CLASS
    Model:
    23 FOOT BURSTNER ( Temporary)
    RV Experience:
    21+
    What happened to the "If its on there it has to work" and why has every tester I've ever used ,test the reversing lights
    Brian
  13. Andy n Loi
    Andy n Loi Guest
    Steve
    Thanks for your reply, its not one of yours, the guy i bought it from imported it direct from the States. I bought it at the end of last year. Ive just tried to wire up a reversing camera to the live feed to the lights , thats when i found no reversing lights.
    I will call and speak to Jason , thanks.
    What would i have to part with money wise to get into a new one with electric step, awning, etc etc.
    Mine is 3100ss ltd registered march 08 , 3000 miles as new apart from reverse lights.
  14. signature
    Jan 20, 2010
    301
    11
    Wolverhampton
    RV Type:
    a class
    Model:
    Thor
    RV Experience:
    over 20
    Andy
    Hate to say it, but the reverse light issue could be down to the 12 volt light conversion that was done.
    Give Us a bell Jason can talk you through a few things.
    Why not just fit electric step and awning to yours.
    steve
Share This Page
